RE: depron rigger- homemade
Try the short one first, they should work. You can always change to longer ones.
You can't change the prop angle TOO much as the front sponsons are not adjustable (on mine). If you lift the rear too much you will need to redo the angle of attack of the front sponsons (hard to do when not adjustable).
