ORIGINAL: Heliko
Your flights should be longer.
Are you still using the stock motor?
Is there any drag anywhere?
Does the DX7 Rx requires more power?
I just change over to seperates and put a Park 370 brushless motor in for the main. Now my flight times have jumped from 7 min to 13min. So far, I'm happy about that and my head speed. The problem I'm now having is that my throttle hold does not work for my tail rotor and even at the lowest position, the Eflite 90 Gyro that I now have installed will turn it on every time I move the helicopter. I am using the stock tail motor with the GWS ICS-50 ESC. I removed my Ebord and am using an Eflite 20 amp brushles ESC for my main. Does anyone have any suggestions on getting the thottle hold to work with seperations?
