RCU Forums - View Single Post - engine cutting off problem
Old 07-26-2007 | 07:56 PM
ehroof
Default RE: engine cutting off problem
sure you can, just run it a little richer, turn the high needle counter clockwise a 1/4 turn and see if that helps. if you dont have a temp gauge, you can put a little water or spit on your finger and wipe the head of the engine with it, if it sizzles away immediately or within 2 seconds your too hot, if it evaporates in 5 seconds or more your ok.
