RCU Forums - View Single Post - Nitro Models
Thread: Nitro Models
Old 07-26-2007 | 08:35 PM
opjose's Avatar
opjose
Default RE: Nitro Models
Most of there planes are VERY good but as with anything there are always a few caveats.
- Manuals are very basic.
IMHO you should have 2-3 prior ARFs under your belt before you tackle a minimally documented plane on your own. If you have access to someone more experienced use them to help you out.
- Covering
The covering used does NOT hold as well as Ultra/Mono coat when exposed to fuel. Trim tends to come off. However there is a simple fix for this...
Use a plastic kitchen dish pad, and go over the Chinakote. Then spray it with Top-Flite CLEAR Kote a couple of times. Go over it again with the pad once dry.
The covering will dry to a shiny dull finish which looks great and keeps fuel from seeping under the trim. Once done the trim stays put.
- Hardware
Some people have badmouthed the hardware provided. It's not better or worst than that provided with most inexpensive ARF's. You should always opt to change out anything you may think suspect.
- Re-inforce
As with any ARF INSPECT AND RE-INFORCE always. For big tailed planes, CF rods work wonders. Expoxy in additional hardwood gear blocks as possible.
Epoxy/CA exposed wood joints as possible.
- CMP kits.
Those sold as CMP kits ARE CMP kits. Note that NP also has a few less expensive knock offs, but they have phased these out.
- If you have a problem
PM Nitroplanes HERE first. "John" answers PM's and is fantastic in dealing with errors, replacements and parts issues.
