ORIGINAL: rcjet lynch
I was pretty sure it would work but had never tried it. I do appreciate the feed back. Digitech I was not using it for more antena purpose but only to split the load on the reciver.
Wouldn't you be better off using a Emcotec or powerbox if you want to reduce the load on the receiver? From what I read if you have a voltage collapse, these receivers reboot. Might be cheaper than 3 receivers as well.
