RE: Great Planes Combat Spitfire GP/EP ARF
Jeff,
Thanks for the tip. If you are not going to fly combat with streamers, you might as well make it fly scale.
The tail assembly was straight forward and the instructions had plenty of detail. If you follow the instructions, the split elevator halves assemble quite easily. Note that I routed the antenna wire through the fuselage and out the aft end. A little grey paint helps hide the control horns.
