RCU Forums - View Single Post - Loose CA hinge help
Old 07-27-2007 | 03:57 PM
jetmech05
Default RE: Loose CA hinge help
I never use ca hinges, what do you think of this? drill a hole through the rudder and the hinge the size of a tooth pick. epoxy a toothpick or 2 into the rudder through the hinge sand flat and recover.
or cut the hinges loose reslot and install new higes.
