RCU Forums - View Single Post - Loose CA hinge help
Old 07-27-2007 | 05:35 PM
Dr1Driver
Default RE: Loose CA hinge help
I personally like the toothpick idea, only I'd use thin CA. Drill 2-3 holes in each side of the hinge, push the toothpicks through, and put a couple of drops of CA on each one. Cut the ends of the toothpicks flush with the surface.
This will work fine for a trainer. If it was a faster, more maneuverable sport plane, I'd recommend replacing the hinge or cutting the rudder off and rehinging all of them.
Dr.1
