Got my Dave Patrick Edge Today!!!
The wings are set up for EITHER single or dual aileron servos. All the necessary harware including linkages and hatches are there for the second servo, you just need to cut the Ultracote out and install the hatch. Pretty nice setup. The plane is setup for a single elevator servo w/ pull-pull linkages, but there are cutouts in the rear for dual elevator servos if necessary. Again, all linkages are included and you only need to cut out the Ultracote as the openings are already there. A lot of nice options on this one!
