Got my Dave Patrick Edge Today!!!
Yes, the hatch for the second aileron is provided as well as all of the mounting hardware and the servo linkages/horns/etc. The hatches are already covered and the only additional work you have to do is to cut the Ultracote on the wing where the second hatch opening is. This plane has a tapered aileron and this coupled with the geometry of the wing should not be as prone to flutter as others. I'm just going to make sure to have good, solid connections and a servo with over 100 oz-in of torque and flutter should be a non issue as long as I keep the speeds reasonable. I think the second aileron will only add extra weight.
