RCU Forums - View Single Post - Ignitions on A123 Cells??
Old 07-28-2007 | 09:22 AM
camss69's Avatar
camss69
My Feedback: (46)
Default RE: Ignitions on A123 Cells??
ORIGINAL: aerobob
Nick - I'm only using ONE, two-cell A123 pack that I made from the DeWalt 36v pack. I installed TWO 22ga male connectors from + and -, and ONE "three wire" male with the orange wire on the center tap between cells. This male mounts to the fuse side in an Ernst housing, and I have the output connector from my Cell Pro wired so that the "node" wire is the orange wire. It works just dandy (thanks to Dick for working with me to come up with this solution). This configuration permits the on-board three wire switches to work normally. I just don't charge through the switch anymore.
To power the ignition regulator, I'll use a "y" off of one of the switch battery input leads.
Ahhh... I PM'd Dick a few times but didn't really "get it" we're doing basically the same thing, I was thinking he was saying to have two leads coming from the pack going to two separate switches each with a single lead to the RX.
This plane is for another person and he's using a "old" JR PCM RX, I don't think I should "Y" the ignition off the main pack without being on 2.4.
