RE: Micro Cessna 210 RTF Electric
I made sure that the push rod was free to move, none of the decals were touching it. I also made sure the hole was open enough not to bind it. I also tried switching the control rod into a different hole on the elevator horn to give it a little down deflection and then trim it to nuetral. BUt when I do that there is no more Elevator movement. So I put it all back to factory where it had up movement. It most likely is a problem with the servo, it just won't push it from nuetral, it will pull it though. So I took it =back.
