RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 07-28-2007 | 04:22 PM
  #1653
Ralphbf's Avatar
Ralphbf
My Feedback: (27)
Default RE: gas fuel with glo plug no ignition
I read back to page 78 and didn't see what you are running.
I assume you are using 10/10 glow fuel.
You may be a canadate for 15% nitro.
The test is if you remove power and the idle slows more than a couple 100 rpm.
Oil content isn't as important as one might think, as long as there is enough.
If you have 15/18 or something close mix up a small test batch and give it a try.
