RCU Forums - View Single Post - Need help with engine problem!!!!!!!!!!
Old 07-28-2007 | 07:44 PM
bruce88123
Default RE: Need help with engine problem!!!!!!!!!!
ORIGINAL: Missileman
ORIGINAL: bruce88123
ORIGINAL: delman
Either that or the clunk line has a pin hole or came off in the tank.
That shouldn't have an effect until down to 3/4 tank or so unless the end of the line is floating high in the tank. I got the feeling that this was at near full tank levels.
It will if you raise the nose up.
He sais he was lowering the tail while on the ground or tilting the nose up, NOT that he was picking the plane up and pointing it at the Sun. I was answering to the conditions HE was going through in which case I was correct.
