RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 07-29-2007 | 08:22 AM
  #1664
borna
Default RE: gas fuel with glo plug no ignition
I'm trying to use a Walbro WT-644 carb for my GMS 120 glow to gas conversion. The primer bulb is on the way of prop washer. Is it possible to remover the primer bulb from the carb, and if yes beside unscrew and remove it, anything else needs to be done?
Borna
