I believe I'm loosing front crank bearing in it so I don't run it any more.
But I have parts on the way.
Yea, I need to check my bearings also. I noticed a little play at the end of the spinner. (about .020" movement at 5 and 3/4 inches out from the crankcase). At first I thought it was due to the crank bearings being in a hard rubber mount, but now I'm not so sure. Where did you order your bearings from?
