RCU Forums - View Single Post - Why are trainer radio controls set up different from 3D???
Old 07-29-2007 | 10:20 PM
jdetray's Avatar
jdetray
Default RE: Why are trainer radio controls set up different from 3D???
Darticus -
The thinking behind the Mode 2 assignments is to always keep the main "turning" controls on the right stick. With a 3-channel plane, that's rudder and elevator. With a 4-channel plane that's ailerons and elevator. This is designed to actually make the transition from 3 to 4 channels easier, since you'll always do your turning with the right stick.
- Jeff
