RCU Forums - View Single Post - Two Engines Vector Thrust Versus One
Old 07-30-2007 | 04:42 AM
bradswan
Default RE: Two Engines Vector Thrust Versus One
I've started to venture down the path of 'altering' the original boat. I've ripped out and cleaned up everything inside the plastic hull. I've taken out the two propshafts and put a new one in the centre. I lined the new propshaft up with the original shafts, i.e., I drew a line between the two original shaft holes and set the new hole in the middle of the rear of the boat at the same level. I hope that was the right thing to do. My question is, does it matter what angle I have the drive shaft at, I know that will impact the angle of the propellor in the water. This is a surface drive set-up and as I said I lined the propshaft up with the original shafts, just not sure what angle to put the shaft at. Hope this question makes sense.
Cheers
Brad
