RCU Forums - View Single Post - Boomerang XL boooms, main gear, hatch Q's
Old 07-30-2007 | 04:44 AM
extra 300
Default RE: Boomerang XL boooms, main gear, hatch Q's
Hi guys,
I am building my XL version I and I have a couple of questions for which would appreciate receiving feedback:
1) Understood that XL version II has wider air intakes due to their swept back shape. View I have the older version with narrower (straight) air intakes and plan to use a Behotec 165 (37 lbs) turbine. Do I need to modify air intakes? Will I experience any problem with this setup?
2) I also plan to install a smoke system and was thinking of installing 2 x 12 Oz Sullivan flat oval tanks attached to fuselage sides behind air intakes. Do you think they will obstruct air flow? Ultimately where should I fit same?
3) With my intended power plant to use on the XL, do you think that gluing the wing without bolts would be safe enough??
Appreciate very much your feedback by return.
Regards.
