RCU Forums - View Single Post - HOTSPOT
Thread: HOTSPOT
Old 07-30-2007 | 10:50 AM
  #75
USSCAT's Avatar
USSCAT
Default RE: HOTSPOT
Hi Guys,
Does anyone know where I can get couple of the phenolic tubes for the wing? My kit was missing one and the guy that I bought it from got some 20 mm carbon tubes that fits the aluminum tubes perfectly but the wall thickness is thinner than the phenolic material. it is a bit loose inside the wing.
I finally resolved the speed brake problem that I had. I dropped the box frame floor where the cylinder was mounted to by 1/8" and machined a aluminum adaptor to fit the horn that was installed. It is operating like a dream, it sounds pretty coooooollllllll. I guess I will hook it up to the brake line air supply....any comments or suggestions would be appreciated.
