RCU Forums - View Single Post - CANARD MIXING
Old 07-30-2007 | 02:29 PM
HO-229's Avatar
HO-229
Default RE: CANARD MIXING
Not yet...
We are working on the vectored thrust mount & expect to bench check it this week.
The vector thrust mount that is to be tested is truely amazing.
We will test the mount @ 3-5 degrees deflection then move up, so max pitch gives about 5 deg motor vector
If things go well... aircraft #2 will have vector thrust/canard/elelator/no spar
Aircraft #1 is a pig & will meet the dumpster soon but we still want to get some max canard throw data points.
