RCU Forums - View Single Post - 4*60 Wing built upside down
Old 03-14-2003 | 05:35 PM
Crashem
Default 4*60 Wing built upside down
So, there will be a large, /\ shape gap if I do what you recommend. Can I insert a rib-shaped "shim" to fill in the gap?
Fill as best you can. then use light fiberglass cloth over the top when you are done and the wing is covered you won't know the difference.
