RE: Super New
Yeah that place is not too bad but if you order like a whole new fuselage watch out for little broken things. So far the only thing i got that had a flaw in it was a broken gear. Oh and what channel is your plane if you've noticed things are cheaper like if you just buy the Rx it cost just as much as a whole fuselage w/electronics which is weird but good for the buyer. Otherwise good luck on your plane. Oh and just so you know the pipercub once you get better at flying it can fly with an extra 3-4 oz on it i just flew with a camera on it that weighed around 3-4 oz you do have to fly on full throttle and be really gentle with climbing and turning. Also for taking off i found that if you put up at half throttle then go from there and control with the rudder you can take off easier if your plane is a little bit tipsy after take off becarefull with turns because you can hit your wings and cartweel=very bad.
