RCU Forums - View Single Post - Grass landing and take off with the Blade CPP
Old 07-31-2007 | 12:34 AM
Xride
Default RE: Grass landing and take off with the Blade CPP
ORIGINAL: soop7667
If you have any problems with the piece of silicone tube holding your tail blades falling off, I've found that you can use a rubber grommet from the canopy mount. It fits very snugly over the "stock" piece of tubing. I also have a habbit of supergluing my tail blades on to the drive gear.
I have noticed it gets loose pretty easy, I was thinking about glueing that little peice of tubing onto the shaft. or at least the bearing into the tail so when the tail rotor falls off its one less part to buy.
