RCU Forums - View Single Post - Home made smoke pump - DIY
Old 07-31-2007 | 04:49 AM
i3dm
My Feedback: (51)
Default RE: Home made smoke pump - DIY
pumps are at www.jetjoeus.com
SS tubes are 1\8".
jowflyer this ESC has a EMI filter on board ! but i use a Medusa Research opto isolator on the wire anyway, to cancel interference and to disable the BEC which isnt needed in this case.
the manual says that if youre getting interference you need to ground the body of the motor to the EMI filter, should i do this despite the opto-isolator on the wire ?
