RE: Broken Receiver Antenna Wire
If you are going to use a solder connection for the antenna repair, get some small heat-shrink tubing and cover up the solder point. Shorting the antenna to something metal (landing gear for instance) can cause RF noise and can intefere with your received signal. Putting a length of heat shrink tubing over the repair will insure that the antenna is completely insulated.
This is just a short and simple precaution.
