Hi drdoom,
As you will see from the (not very good) photos I cut a little of the nose wheel cassette away to accommodate the door cylinder.
My F16 at 17.5lb dry is fast with the Wren 54 MK3 at 14.5lbf. Yours with the P70 should be very interesting!
Rgds,
Eric
ORIGINAL: drdoom
I looked those over very well before I begain building. But you can never get too many ideas.
I got the kit instead of the arf so Nothing was installed. I have had a lot of fun putting this togather.
I bought Jet Model Products Air accumulator for the doors and the gear. distributes equal air to each component at the same time.
I am also using the JMP sequencer for the gear and doors. Using a JR 10X with the DS-8711 servos on the horozontal stabs.
p-70 for power.
