RE: Black Magic VF3 Build Thread
When using the balsa stripper adjust it to make perfect 1/4 square stingers. Use one of the formers to test the stingers in the notch. Tab the former into the fuse side and check the fit. Small adjustments to the stripper can make a huge difference in fit. If anything you want the stinger to be just a bit too big than small.
