RE: H9 Quality!!!!!
LuftwaffeOberst looks pretty good. We are our own worse critik!!![>:] Set the temp just high enough to get the covering to stick. Using a lower temp prevents gas bubbles from forming.Then I go around the edges with monokote trim solvent with a Q-tip. Tower Hobbies part # LXHZ43 Let it dry for a while then clean off the excess with with windex or your usual airplane cleaner. The trim solvent seals the edges so it will never peel off. No more worries about gas bubbles from a hot iron. I also do this on my ARFS . Covering that peels is a pet peeve of mine![sm=tired.gif]
[sm=devious.gif][sm=disappointed.gif]
