RE: redcat tornado problem
it actually sounds like an air leak, probably the base of the carb, head, backplate or front bearing. if you want, when you have it running spray some nitro fuel on the engine from a spray bottle in the areas i said above and see if the rpm's raise, if they do then thats where the air leak is.
