RCU Forums - View Single Post - retract Q
Thread: retract Q
Old 07-31-2007 | 10:14 PM
Cyclic Hardover's Avatar
Cyclic Hardover
Default RE: retract Q
ORIGINAL: tonywayne
Thanks. so does the spitfire in my initial post... '' http://www.nitroplanes.com/spitfire120.html '' need rotating or nonrotating retracts? Regardless of there recommendations. Thank you......
Beats me, I'll take a look------yes, 90 degree rotating. its in the fine print between the large photos. It says it can be fitted, I don't know if the linkage is already in it or what. Why don't you try and ask in a separate thread titled Nitro Spit and see who has one. I set up a couple planes for friends with the rotating. The bellcranks are the area to get right. I even Installed an access door on them to make it easier to fix problems
