RCU Forums - View Single Post - World Models Trouble
Old 07-31-2007 | 10:36 PM
cwesh
Default RE: World Models Trouble
I am another one that thinks something is "fishy" at WM
I found problems in the wing of the Sky Raider Mach II, the shear webs were not glued to the top spar, only the bottom. I found this out by giving the wings a slight twist to see how stiff it was, it felt sloppy. Since I am not a fan of that cloth like pattern on the covering, I ripped it off and found the shear web problem, a bit of glue and new covering and it is now nice a stiff in twist. Why did I check that?, don't want to bust a wing while racing! (Club 40)
Later I got another plane as a backup, recovered it to match the first and found the same problem in that one too. Since then, 3 other Sky Raiders at the field have had the same problem.
Where is gets interesting is, I got a wing from a crashed one as parts, this wing came from an older plane. One mid-air later and I am using the right wing panel to fix my #1 plane. The shear webs on the donor wing were well glued. Humm......
FWIW!
Later!
