RCU Forums - View Single Post - CP Pro Interference! STATIC OR RADIO OR???
Old 08-01-2007 | 02:19 PM
FMB42
Default RE: CP Pro Interference! STATIC OR RADIO OR???
Also check for a loose Tx antenna connection and or bad solder joint at the circuit board. I had a coax do the pretty much the same thing and it turned out that the Tx antenna solder joint to the main board was cracked.
