RE: Top Flite Cessna 310 posted
Well I am ready to Maiden this weekend
2 x 55 Ax engines, exhaust extensions, twin sync and robarts
If you remember i took most of the lead shot out of the nose and she balanced spot on with the batteries in the nose.
Weight is 19.6 pounds, i have balanced her at 87 mm. Has anyone played with the CG yet. I must just check my Air system as I am only getting around 8 cycles before the air goes low. How many cycles should I expect, I am losing around 50 psi overnight !!
Any advice welcome !!
