RCU Forums - View Single Post - Fail Safe Setup
Thread: Fail Safe Setup
Old 03-12-2003 | 04:24 AM
3DHELINUT's Avatar
3DHELINUT
Default Fail Safe Setup
I have a Futaba 9CHP and a HP5, I am trying to setup the fail safe feature and I am unable to get it to work properly. the 9CHP will not allow you to change the value for the throttle setting. it is set to 25% and can not be changed, this poses a problem when trying to setup the failsafe option.
also what is the correct procedure to set the learn r/c option for the HP5, do I just set it by the trim lever? or do I use the normal setup procedure? what sets the governor mode?
we really need Documentation ASAP.
Alan...
