RCU Forums - View Single Post - GP GEE BEE
Thread: GP GEE BEE
Old 08-01-2007 | 07:40 PM
  #266
stearmanmike
Default RE: GP GEE BEE
Bax
I took a photocopy of my plywood parts sheet before I assembled the parts.
I can measure it if you like, or maybe try and email you a copy of the sheets....four sheets make up the complete picture if you understand what I mean.
Just not sure if the dimensions would come out right once its been scanned and emailed, but if I supply you the dimensions off of my Gee Bee of the original cowl ring you can use the photocopy as a template to make another if you need it, but I reckon it would be a real tricky job to do unless you know someone with a laser cutting machine.
The cowl ring only comes with the fuselage set off the tower hobbies web site, although I did order a spare cowl from tower and it DID come with two cowl rings which you epoxy together to make one.
....Let me know if you still need help......I'm in the uk
Regards
Mike G
