Info needed on FP-T6FG and FP-R107Q
IF THE PROBLEM THAT YOU HAVE IS IN THE THROTTLE, IT IS OK. THE THROTTLE STICK HAVE LIMITERS THAT REDUCE THE MOVEMENT AND THE TRIM ONLY WORKS IN THE IDLE POSITION, IF YOU MOVE THE TRIM COMPLETELY TO THE IDLE POSITION YOU WILL NOTICE MORE THROW.
REGARDS
ALFREDO
