RE: Redundancy setup without power box?
Hi Daniel,
This is why I use Deans connectors on almost all my products. You would have to make some adapters for the Deans to JR plug connection to the receiver. You would have 6 amps continuous with two connectors. The 7.5 amp rating of the regulator is its maximum amp rating. Using JR plugs you cannot utilize the SuperReg to its capacity.
All the PowerExpanders work with the Spektrum receivers.
Let me know if you have any other questions.
