RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 08-02-2007 | 03:33 PM
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
Place the taped together fuse crutch along the center line against the tail block. Place a small strip of the craft wood infront of the firewall to hold the fuse in position. Tack that small piece of wood in place capturing the fuse in position.
Mix up a small batch of 5 min epoxy. Start at one end of the fuse and glue the stations to the base, one station at a time ( both arms of the station ) hold the stations in place with the center guide of that former in alignment with the center line as it cures. Be neat with the epoxy as not to get any on the fuse side. work alternately gluing one set of stations from the front and rear of the fuse until you have all the stations in place always keeping the laser cut center guides of the formers aligned to the center line of the base board.
Just take your time and glue the pairs of station arms in place along the fuse. Once you get started its really easy.
