RE: gas fuel with glo plug no ignition
Try the 15% nitro and 10% oil. It should work fine. If not, you can just lower the compression ratio a touch, but it should be no problem. Don't add extra gas to the mixture. 2 parts high test gasoline to 1 part glow fuel.
AV8TOR
