ORIGINAL: tmdz28
yeah, i cant take out the backplate right now. i am talking about the 4 screws that holds the backplate. if i open up the back plate i would be able to take the crankshaft out. it is the backplate that is between the block and my roto start plate[&:]
The only option for you is to grind off the head with a drill or a Dremel with a small enough stone so you dont damage the backplate.
