RE: Brake problems
ok well i figured out that the standard servo simply wasnt strong enough to pull my brakes tight. I pulled my high torque servo out from the steering and put it on the throttle/brake and the standard on the steering. It works good now but i stripped the teeth out of the horn. servo is fine i just need a metal horn i think. also i think i should have set the servo throw lower because the servo is so strong is just kept going and stripped the horn teeth. Im definately happy at this point tho because i know whats goin on. Also i wanted to ask are there bodies for sale anywhere that fit the avalanche? the one i have looks cool but it doesnt have a hole in the truck bed for the glow plug, its a real pain taking it off just to start it then putting it back on.
Defm~
