RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-03-2007 | 07:05 AM
  #1697
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Glad to hear you're doing ok and getting better Captain.
shaunmichaeljohnson - These conversion engines tend to be fairly low compression and like the nitro for the most part. But that is true; if the compression were high enough the nitro wouldn't be necessary. However, a slightly lower compression ratio used with nitro makes more power, and has a nicer idle and transition to higher rpms than an engine without nitro.
AV8TOR
