RCU Forums - View Single Post - Pacer hinge glue
Old 08-03-2007 | 09:06 AM
da Rock
Default RE: Pacer hinge glue
BTW, what I noticed about the installation of the CA hinges with this glue might be overlooked by some beginners.
The slot needed is thin, very narrow. And you're probably going to want to use the slots already cut into your ARF. The hinge glue is fairly thick stuff. I noticed that when I started using it with the Dubros. So I've thinned mine a bit. It still works great on the plastic hinges when thinned. I know that because I tested the thinned stuff also.
So when I did this test, I had to hold the glue nozzle firmly against the slot and squeeze for awhile. And I then slid a straight pin down into the slot and wiped the glue down into the hole. Then I coated the CA hinge. When I slid in the first one, the glue had a tendency to grip. That's not surprising. But I'd keep that in mind and be prepared when doing this on an almost finished airplane. On the second test hinge, after I'd filled the slot and coated the hinge, I dipped the coated side into a small cup of water to make it easier to slide into the slot. It went without a grab. I did 4 hinges into the scrap. Didn't do the other half of the job because I intend to grip the hinge sticking out with pliers.
time to go fly....... good sky, good wind, just a bit warm........ gonna be an EXCELLENT day! But then, any day flying is an excellent day....... see ya'
