RCU Forums - View Single Post - Gap sealing......
Old 08-03-2007 | 10:47 AM
rlipsett
Default RE: Gap sealing......
Make sure when you seal the gap that the hinge is fully deflected before attaching the gap seal. Gap sealing is usually a good idea small 3d aircraft that use ca hinges. It reinforces the hinges and helps to reduce the occurence of flutter on large surfaces with extreme deflections. and cosmetically it looks neater
