I just got a line on a Iron Bay Regulator locally. Will put it in tomorrow.
Have a couple of questions If you guys dont mind answering.
1. The minimum hose length on my setup (closest I can mount it) Is 3" away.Is this Okay?
2. Being there is a check valve now going on ,on what used to be my fill vent (pressure tap) I take it I need to do a 3 line setup?
3. Put the needle settings back to break in position? Or is it going to need more then that?
This is on a Saito 180 with a Slimline Pitts mounted inverted.Running the last gallon of Coolpower MV 15/18 through and switching to Omega 15% The engine has run rich its entire life (3gal.) as I have never been able to lean it out properly.
Also changing to a new Glow plug tonight. Although I do not see anything wrong with the original, gives really good idle ,but Ill take the advice of the experienced ones
