RCU Forums - View Single Post - Pacer hinge glue
Old 08-03-2007 | 06:46 PM
goirish's Avatar
goirish
Default RE: Pacer hinge glue
Hi, I did a test with the glue by seeing if it would wick into the hinge slot with the hinge already inserted--it would not. Then I put a thin layer of glue on the hinge and put it in the slot--after approx. 45 min. was unable to pull the hinge out. Then the next test was to do 3 hinges in a sample aileron--I wet the hinge first and then applied glue to the hinges--was able to put all three in both sides with ease. Flexed the aileron to line up the hinges and waited approx. 1 hr. was unable to pull apart. This maybe my answer to using CA hinges without using CA. If anyone else tries a test please post it. Thanks
