RCU Forums - View Single Post - How Do You Work With Metal?
Old 08-05-2007 | 09:30 AM
eagledancer
Default RE: How Do You Work With Metal?
for small brass fittings i use aviation hand shears cut oversize and then use bench grinder to get close, then take a file to finish. for cowls i use the drill lots of small holes, use a small jewelers saw to cut between the holes then file to shape. i have several files different shapes and courseness.
