RCU Forums - View Single Post - Ignitions on A123 Cells??
Old 08-05-2007 | 04:04 PM
Bob Pastorello's Avatar
Bob Pastorello
My Feedback: (198)
Default RE: Ignitions on A123 Cells??
Finished phase one ground tests (limited range use, but engine running, all settings) with the A123 feeding a MPI 5.4v, 10A regulator.
All worked fine.
As expected, total milliamp draw from the A123 was as much as anticipated, indicating the reported current draw of the RC-EXL ignition is about as stated.
There were no issues, nothing to report, really. Solid, reliable performance and nothing visible in radio-land because of it.
Way too hot/windy for me to do more, so I just continued breaking the engine in.
Phase two will be at the field, ground tests, bind button depressed to find engine on/off limits to range, all attitudes of airplane. If all's well there, then there is only the airborne test remaining.
