RE: Balsa USA 1/3 Scale Sopwith Pup
BobH
Your cockpit photos look great. My Arizona Models cockpit kit does not come with a compass. I have built cockpit and it came out great. I will post a picture in the future. Could you shead some light about your compass. How did you build it? Any building photes you would like to share? I hope to have it complete before the end of September. I finished building a Mick Reeves dummy engine for the Pup this weeked. Because the Zenoah GT-80's prop hub is not long enough to fit the dummy engine inside the cowl with out butchering it up I searched the net and found a 1 1/2" longer than standard prop hub. This will allow me to use the dummy engine and still clear the cowl. I am also going to explore changing the landing gear to scale with the bungee chords.
